TN PJ91 Hauptuhr
TN PJ91 Hauptuhr
Hello from Sweden, I got a problem with my "new" Master clock. The hands move but the wheel moves also all the time. What could be wrong?
https://youtu.be/Dfmicgbqpis
Re: TN PJ91 Hauptuhr
Hello from Vienna, the escapement doesn't work therefore the movement runs contionously. What I am also missing in the video is a pendulum,
seems that some important parts are away.
ng Christian
ng Christian
The pendulum I got but makes no difference to the movement and it´s problem of movibng about all the time.
Whatever, without detailed photos from the escapement group it's not possible to say more.
Especially escapement wheel and anchor are from interrest.
ng Christian
ng Christian
Let me aske you, what is the escapement group? Is this the stuff up at the top left corner? Sorry about my very low knowledge!
Here you will find a detailed description for the Graham-Escapement:
https://www.princeton.edu/~timeteam/graham.html
And on the bottom of the site you will also see a picture of the parts what are interested for us.
ng Christian
ng Christian
The Escapement?
No, definitely not.
It must be between the two rectangle plates in the middle of the upper half of them. But it can be that this are the missing parts in your movement.
ng Christian
ng Christian
Ich würde da erstmal vermuten: der Nachstell-Hebel hebt den Auslöse-Hebel an und deshalb kommt das Werk nicht mehr zum Stillstand. Hebel rechts hinter dem Zifferblatt einfach mal nach oben bewegen... wie wärs?
